i want to work with military grade computers what should i know or learn that will give me a leg up on collage or the military's school?
Well military grade computers are really just hardware stuffed with extra quality parts and build differently to function under hard conditions.
I know a guy who worked for the military once, also within IT. He went to work for the military setting up secure networks for government communication etc.
I asked him about this question once, and he said that all he did was take the normal education like computer science, Cisco Certified Network Architect and some infrastructure stuff.
Its really more about luck than skill, since the positions only open up like once every 30 years or so. Even then its good to have a backup plan, like normal networks or programming etc.
Just like with almost any industry out there, there are many computer related jobs in the military and replated industry, so being a bit more specific in what you want to do would help. Do you just want to do a normal computing job but just for the Military then just take whatever normal training you need to and then just take whatever type of training you would for the civilian version of that job. If you're looking to work in encryption then take a normal computer science course and add in some modules on encryption. You get the idea.
As Zuse said, the only difference between "military grade" computers and regular ones are the quality of the electronics components that are used. "military grade" electronics components typically are made so that they fail less frequently and are made to within much more precise tolerances. Mind you this mostly applies to the specialised computers the military uses, like the ones in radar systems and in missile guidance systems. The Dell laptop an a general's desk is probably not going to be much different from the one you can get from BetBuy. If you do want to get into that kind of computing then a course with a bit of programming and electronics will probably be what you want.
The big thing I will advise is make sure you keep a squeaky clean image, don't ever get caught breaking any laws (you'll probably get away with traffic offences, you probably won't with drug offences) and try to stay out of any countries that are unfriendly to your country. The reason being that for the types of work you are looking for you will almost certainly need security clearances and in my experience the guys who issue those clearances do not give a rats arse how talented you are unless you're a Steven Hawkings level genius (in which case a superior officer will overrule them, but this is really rare). And as sucky as it is try not to be publically associated with any groups that may seem unfriendly to the military or any part of the government. How far they take the checks will depend on what job you are doing.
