Hey guys; any idea where I can get this molex to 4-pin 5-way fan splitter, but from a UK vendor?
**Grammared**
**Grammared**
WHAT???? wear to buy? your question makes no sense
pretty much the same thing
I fixed the grammar.
Cats usually have pretty bad grammar. You are the one exception
Thanks brennanriddell for fixing my grammar, Dyslexia strikes again.
Thanks for the link Will, was hoping to get one that gives the same voltages across all connections but if that isn't an option i'll just have to get 2 of those.
