Windows has become a real PIA and I’d like to move towards using virtualization and Wine/Proton to replace it (I need to find tutorial on how to use Proton for general applications).
My question is where are we standing right now for virtualization and hardware allocation?
I’d like to have a setup like this:
Linux OS that is used for daily driving
- uses containers or VMs for individual projects to keep things clean
Windows VMs that I could use similar to Windows Sandbox
- i.e. load a blank, load software I need temporarily, run, delete for software I want to keep isolated from the rest or run only on a clean system
Main Windows VM for applications that I’ll regularly use and can’t transfer to Linux and require other pieces to function
- Xbox Game Pass has been good to me
Also since I’ll be using each different system for tasks that may require the GPU (games on the mains, AI on the VMs/containers) I want to be able to use my GPU for all of this and have it dynamically balance allocation so that I can fully utilize my GPU when I’m gaming exclusively on one thing or the other, or I can mix and match slightly if I’m running a few light games or tasks simultaneously across them.
Is this possible with current software/hardware?
What does it require and what do you recommend?
Note: Something I’ve also considered is a main hypervisor that does nothing but manage VMs and let me passthrough video so that it basically stays completely clean from everything else. That’d likely be inconvenient when it comes to the Main Linux system and all the passthrough I’d have to do.
