em4n3m
1
Hi,
As per subject I have installed my Arctic Freezer II on my X570 Taichi, but I had to basically bend the guides.
Picture here.
Is this expected?
Again, I followed the provided instructions and removed the mobo plastic sleeves and then used the same screws to fix it.
Seems to be stable, though the bends are quire noticeable.
Have I done it wrong?
Azulath
2
I can’t see the bend you are referring to.
em4n3m
3
Look at the support staves, those are bent.
Anyhow, I found out I installed ‘wrong’.
Apparently I should have mounted the harness as rev3, instead the included link brought me to rev2, and that’s how I ended up mounting it wrong.
I have now unmounted and remounted again according to rev3 manual and although the guides slightly bent, seems to be stable.
Have been running stress -c 32
for 12 30 minutes and counting. No slowdowns nor shutdowns.
em4n3m
4
60 minutes and counting of stress -c 32
. All good.
I hope will stay so over time.
system
Closed
5
