Hello,
I’m not the best at computers, however, I have been having a problem were if my computer’s cpu gets above 70% it starts making a beep sound (I get the amount by a program known as “CAM” a friend of mine recommended it to me a couple mins ago.) My computer also randomly restarts without a blue screen every couple days. It’s getting on my nerves and I’m not quite sure what to do.
AMD-FX-6300 (Yep I know its quite bad when I built my computer I had no idea about it)
Nvidia GeForce GTX 960
Windows 10
Power supply? Thermals? How old is this issue? Have something happened, like q storm or electrical maintenance or something a bit before the issues occurred for the first time? Have you checked your hard drives for problems?
This issue has been going on for about 2-3 months I’d say, I have had this computer for like 2 years and out of the blue it started happening.
Nothing odd has happened tbh. I didn’t check anything as I’m not sure what to do and not trying to mess up anything.
10-60 is a pretty big range lol. What I would do to rule out an overheating cpu is run prime or some other cpu stressing program and at the same time have your cpu temp monitor up. If/when your computer starts beeping, record the cpu temp.
First thing I would do is try and find a powersupply from a friend or something, just to test if yours in’t dead, cause if a power supply unit dies, it takes away EVERYTHING ELSE with it.
Could be a graphics card thing that could be because of the power supply…
By the way, I have a friend, who had a similar issues. Try moving your graphics card to another PCI-e slot…
But really, if this doesn’t work, try and find another power supply just to test…
What motherboard are you using? I have a similar beeping issue for a few years now when my Northbridge hits ~85°C when the CPU is under load for a while and I have half a cat stuck to my front intakes. It may very well be that some components on your board are aging and get hotter over time.
For older AMD CPUs, I have one too, I believe the safe operating temps were only up to 65-75 degrees. So you are all ready hitting that.
It may be that the 70% load is just a frequent correlation point. The reality night be that at around 70% load the temps hit critical and the system shuts down to save itself and that also what’s causing the beeping.
