i'm a console gamer switching to pc gaming and decided to go with the amd fx8350 and gpu 7970 and was wondering if you guys could help me with the rest of my build . i'm looking for a barebones system trying to cut out parts i t hink i could do without for now .
no ssd ,no aftermarket cooler if possible (i don't plan on overclocking right now ). no disk drive, no windows and case( it's cheaper to buy the case in my country) and i have windows 7 .
so can you tell me what parts i need to have my pc up and running and reccommened some good parts for me not too overprice .thanks
the fx-8350 is just really overkill if you are on a budget so ill just go with a "lower" priced 8 core cpu that still delivers in the power department!
Link to the build: http://pcpartpicker.com/p/1Qabr
the R9 280X is basically a 7970 just a teency bit faster and looks damn cool with an almost sexually attractive price/performance ratio.
and the 8120 is still a great cpu. I picked the motherboard with the most back Input Output at the best price, please give me your feedback and what you would like me to change!!
Its a very solid build and will last a couple years with high-ultra settings. The reason i chose the 7970 instead of the R9 280x is because they are so cheap at the moment and you could overclock it to get the same performance as a R9 280x.
