Hello,
So I don't have a lot of money so I thought I would ask what would be the best cost vs use for upgrading my current build? I use it for gaming and editing videos. So what would you guys suggest I do I have about 150.00?
Hello,
save up some more, get an FX-8350
Ah so new CPU ? ok Ill check it out thank you for reply!
Preferably better motherboard with 970 chipset, at least. Also make sure there's cooling on the VRMs if you wish to overclock.
Newer AMD architecture would be the FX-4300. I would recommend at least a FX-6300, though.
Get the 2GB version of that card. It'll help to make sure it lasts a lot longer.
500W of power is enough for a 7850.
Talked to wife I am aloud to get the motherboard with the 970 chipset and I squeaked out a G.Skill Ares Series 8GB(2 x4GB) DDR3-1866 memory. For a grand total of 128.44. My only concern is will the other G.Skill Ripjaws X series 4GB (2 x2)GB) DDR3-1866 memory will work together? I know manufactures won't work but what if it's same manufacturer but deferent series?
If they're the same timing, then they may(mixing and matching RAM kits doesn't always work) work together.
Same timing,same manufacture, the only deference is 4GB vs 8GB. both are the DDR3-1866 for memory, oh well it's a killer upgrade. The motherboard is just crazy.....I should be good for a few years with it. now I can just add, and add, graphics cards upto 4,SSD,it takes upto 64 GBso I can add upto 52GB, and CPU's upto 8 cores.
Thank you Some Tec Noob, you really came through with great advice! I would like to chat with you more on a PM. If you would allow me to pick your brain that is?
Sure, shoot me a PM via the contact function on TekSyndicate if you want.
