I am building a gaming rig with a HD 7870 in it, what would be a good case?
What is your budget?
Umm.. define R4?
Well not know the form factor of the motherboard or plans with the system I'll just agree with the define R4
Nothing too expensive, I am looking for somthing on the cheap side, but I am not looking for a $15 plastic case.
Unless I get a budget, I'm going to default to a Little Devil.
Good point on the motherboard; I personally have an eATX motherboard that pretty much requires a full tower case.
Motherboard, Asus M5A97 LE R2.0 ATX AM3+
Budget?
No more than $60, but thats the max
NZXT Phantom 410, its 40 bucks more but its worth it it, its a great case
well there are so manny cool cases in that budget realy..
This case i realy like the color theme of it, but a case is realy personal.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133200
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235027&Tpk=zalman%20z9%20plus&IsVirtualParent=1
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146084
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018&Tpk=corsair%20200r&IsVirtualParent=1
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235038
just a few cases i personaly like in that budget ☺
Fractal arc midi r2 is the best case on the market at around $100 price point.
+1 to slay english for the Arc Midi R2. Just got it yesterday and it was a thrill to build in. Instant Fractal Design fanboy :D
But back to the question at hand, I have to agree with Gr33nL34f, the NZXT Source 210 is a great case for only $40. If you want to spend a little more, the NZXT Tempest 410 is a great case for only $60. 3 x 120mm fans (2 in front, 1 in back), 2 x 120/140mm fans on top, dust filters on front and bottom, 3 USB 2.0 + 1 USB 3.0, decent cable management, and support for water cooling on top (240mm rads for sure, not sure about 280mm).
Source 210:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075
Source 210 w/ Window:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146102
Tempest 410:
Have it aswell replaced my corsair 200r with it.
