what would be better a CORSAIR Hydro Series H110 Water Cooler or COOLER MASTER Seidon 240M?
or do you guys know of any better water cooler for max of $120
Is it a must for a watercooler? Because if it isn't i would suggest a Xigmatek Dark night II. It cools just as good as a h100i for a lot less. The phanteks ones i suggested are also capable of handling a good overclock. But the monster noctua at the bottom will probably cool better than any AIO cooler on the market.
Dark knight
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029&Tpk=dark%20night&IsVirtualParent=1
Phanteks
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709020
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709011
Noctua
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
I agree with the above suggestions. AIO coolers aren't that great. You could build a custom loop for not much more than your proposed budget.
You can obtain a pretty good overclock by spending as little as $35-50.
I second berserker's view. inho aio coolers are rather ordinary for the price they go for. An air cooler with adequate case air flow and you'll get good cpu temps.
i need the cooler for a amd fx 8350 it dosnt need to be watercooling as long as i can overclock with it cause wow the stock cooler is loud and i want to overclock
Both the phanteks 140mm cooler and the noctua 140mm cooler would easily be able to handle a 8350 overclock.
