Hi guys,
I have been wanting to upgrade my PC for a while now but I haven't had the funds. I got my pc in Febuary 2009 it has an Intel core 2 duo 2.4 ghz, a nvidia 9600gt, 4 gigs of ddr2 ram, 500w psu, 500 gig 5600rpm hdd and 1 case fan that's loud as all hell.
I do plan on eventually replacing the whole system but I still don't have the spare cash for a whole system. so my question is what should be my first upgrades, I was considering getting an r7 260 directcu ii from Asus but after I watched a Linus tech tips video about bottlenecking I have begun to consider getting a new motherboard and an AMD FX-6300. Getting the MB+CPU is $30 more than the GPU.
I also plan on getting a Xigmatek Talon because 1: my case is ugly 2: it's noisy 3: it has no air filters so I have to clean it every week. so what does everyone else think, should I get the MB+CPU, Graphics card or is there another component I should get (I am getting the case regardless of what other upgrade). Also, dose anyone know of a good motherboard for the FX-6300 or if I should get a completely different CPU.
Well if you plan to get a new CPU+MOBO, you are going to have to get a new set of RAM as your current DDR2 sticks won't be compatible with the FX-6300.
+1.
I suggest save up for a full clean builds. You may be able to use the old hard drive, but that PC is outdated and most parts will have to be replaced.
Any upgrade that you want to make will prove unbalanced with the rest of your system. Starting anew, saving for an entire build might be the way to go.
Though, in the interests of cashflow I would advocate upgrading the platform first. A decent platform will last you near 5 years, but a new GPU might require a refresh much sooner to keep up-to-date. You don't want to invest in a part that will diminish quickly before you have the rest of your system upgraded.
Consider the FM2/ FM2+ platform. That will be good for any mid-range card GPU upgrade.
I can suggest this to you http://pcpartpicker.com/p/2IjdA
If you are on a tighter budget a quad core is more than enough power for a R7 260 here is something a little cheaper http://pcpartpicker.com/p/2IjHF
Thanks for all the feedback guys :)
I have a plan... I will get the Motherboard, RAM and CPU. I'm waiting on a few job applications at the moment so hopefully I'll get a job soon. Once I have a job I'll set aside some money for a pc and get the remainder of parts I need to make it a completely new system. Does that sound ok? the whole reason I wanted the r7 260x is because I just wanted a graphics boost for my desktop until I can afford a new pc so that was only a short term fix (I now realize that wouldn't be a very good fix).
You could do the MoBo + RAM + CPU upgrade first, if the computer you have isn't performing as well as you want it to. Otherwise, doing a balanced, complete upgrade would be better. You can always pick up parts if you know it's what you need and there's a good sale going on as well.
I would suggest paying the extra $50 for the R9 270. There is a great performance difference between the 260x and 270.
