I have some spare cash and was looking at upgrading my pc if you guys were me what would you upgrade, why and what would you upgrade to?
Current Specs:
Amd Phenom II 840
16 gb DDR3 RAM
Asrock Extreme 3 970
Nvidia 470 GTX
Kingwin MK Black 650 watt
Creative Sound Blaster Titanium X-fi
Any advice will be appreciated!
I don't know if you have an SSD, but if you don't then that is what i would upgrade to. with that upgrade you get faster boot times, short load times when it comes programs, searching for files, and even games if you install games onto the Drive.
I have an ssd and 2 terabytes of disk storage so thats not an issue I'm paritial between a new cpu and gpu.
i would go for a new gpu first, but what is your budget? and what is your goal with your system.
I would fill this out to the best of your ability even though your are just upgrading, budget, prefered seller, etc
That way we can help you toward you specific needs
Thanks sorry about that, my budget is 200 or less, I prefer Newegg (but other reputable vendors are fine) and I'll be playing games preferably at 1920x1080 at 60 fps on the highest settings possible. I have everything I need I just didn't know what would be a better decsion since both my cpu and gpu are a bit dated.
I would get a 7870ghz\
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404
I know its right at $200, but my friend has had terrible luck with 2 sapphire dual X 7870ghz DOA from newegg, and it runs hot
