So, i'm in this rough spot where i have a good amount of money that i want to use for upgrading my PC, but i have no idea what to upgrade and if its justifiable. I'll list my current pc specs so you guys have something to work off of. I also do know an SSD is an obvious option.
If you're happy with your setup, don't change anything. I think a PC should do exactly what you want, and spending extra money for features you don't need is a waste. Buy something else, or even better, save your money.
naff all wrong with the rest of your PC and if it meets your needs, you dont find it underperforming anywhere no need to upgrade.
your CPU is ivybridge which isnt that old, you have...probably enough RAM, your GPU is plenty good enough (maybe upgrade that next year) all you're lacking is an SSD
Now the real question is what is a decent SSD? I've heard good things about samsung and crucial. I've never owned an SSD so it would be a big jump and trying to figure out how to get 450gb of stuff off my HDD without having to reinstall every game/program. As far as capacity, i think 240-250gb would be good for me. I'd probably put all of the maps for BF4/COD on there to load fast.
i got a samsung 840 evo ssd and so far it has been amazing. What you could do in terms of transferring it is split you hdd into 2 partions, have just windows and the game installs you want on your ssd on one partion and everything else in the other partion, then you can transfer that partion with windows and the games to the ssd, leaving everything else on the HDD
Here is a quick question. What justifies the massive price leap between the pro and evo? Are there some benchmarks? I don't know because if it isn't a significant performance increase for all the extra money it seems kind of pointless to go with the pro.
