It was for streaming DayZ and the like with a budget of $700. It seems to be working great for him so far but he now has $400 for upgrades. I doubt he'll be putting to much more money into the system so I think this needs to go towards rounding the system into a "complete" build.
The only thing I'm not sure about is the second GPU. I'm not sure a 600W Bronze PSU is going to cut it with the FX-6300. What do you guys think? Should he look into a better PSU or just spend the money on something besides a second GPU?
If you have any other thoughts on what he could spend the money upgrading feel free to suggest it! Thanks!
I'm pretty sure most of the games he's playing will support CrossFire. Even if a single GPU would be better it doesn't make sense to replace a 7870 GHz at the moment with his budget. A second one sounds promising though... idk.
the general rule is get what you need +100w when it comes to the PSU...
pcpartpicker's calc puts it at 544 in 2-way crossfire... being that it's not a PSU that I've worked with, I won't say that would be ok...
PSUs are futureproof, it wouldn't kill him to invest in a good one... Corsair has a 750w Pro series gold rated full mod for $90 and 650w TX series non mod for $50
He's been wanting one. Like I said, he streams among other things while playing so it'd be nice if he didn't have to tab out to check every little thing.
I think I will go ahead and recommend a new PSU just to be safe. He can sale his old one and use the money for the monitor later. He had enough trouble dealing with putting the thing together, I'd hate to discourage him with a myriad of bluescreens, etc.
I'm not to worried about overclocking. The stock heatsink is just anemic as hell and needs to be replaced as he frequently hits 90%+ load on the CPU. The overclock in the calculator was mainly just to include some headroom.
I completely agree that he should replace the motherboard but it was the only thing that fit his budget and needs at the time. I also expected him to be upgrading to an i7, so it didn't make sense at the time to spend the extra $40 to $80 on the mobo. I'm thinking better of it now, but he'll probably just have to make due.
