Hey ya'll, I was curious on what to look for when buying a GPU. I am planning on getting a GTX 780 may settle for the 770 if the prices do not come down quick enough for me. However, I am just curious as to why these cards are better and what specifications should I look at when purchasing a new card.
These are my specs right now (with a Sapphire Radeon HD6670)
Well first i need to ask you what resolution are gaming with. If you are using a 1080p monitor then the 770 would be loads if you are/or are planning to move to 1440p the 780 would be better.
BUT the 800 series should be coming out soon so i would wait for a couple for a couple of months, but if you can't wait then yeah, get the 780 or 770 as far as which one you should buy there are a lot of options.
Usually you should consider the cooling unit, overclocking ability, and the quality of the card. I would usually buy EVGA but Gigabyte and Asus are very good also.
decide if you want a blower style or open air style based on the air flow of your case. Then decide on how much you want to spend and get the highest end card you feel comfortable buying
Is there a big difference between the 2GB and the 4GB? I always believe more is better so I am assuming that 4Gb is better than the 2GB cards. Thought?
personal opinion i'd go with one of the evga acx's, as i've heard mixed thoughts on the windforce cooler ranging from greatest cooler ever to hot and loud
basically more vram isn't "better" because often times the card will never use all of the ram (not referring to any card specifically but just in general), so unless you actually need to use over 2gb of vram (at 1080p you really can't use that much unless the game is coded on a whole new level of shitty) you'll never see a difference, the 4gb model is more for sli and extra high resolutions
Personally, when i'm doing a purchase i ask myself:
Why am i buying a new piece of hardware? (last one was a 7970 from AMD).
Do i have other uses planned for that hardware? (mining, folding@home, OpenCL, photoshop, after effects, etc).
How much money am i willing to spend?
What are my alternatives that fill this needs/desires within my price range?
I'm sorry if i'm vague, but once you really get to answer these questions, is when you realize you spent your money well. I didn't go for any manufacturer in specific because each one has its own share of features, and that's a decision you'll have to make based on your own preference and of course, your previous answers.
