The recent drop in storage as well as previous splurge on geek-squad openbox Samsung 970 Pro’s in 256GB has left me with a pile of 2280 M.2 drives and no real good use for them.
As I prep to retire my 1920x Threadripper I’ll no longer have a system that supports VROC RAID and PCIe 4/5 is/will be more than enough for my modest test lab needs, I find myself wanting to put these to good use.
I have 4x 970 Pro 256Gb, 2x 970 Evo 512GB, 2x ADATA sx8200 500GB. I need a box with 10GBE and the ability to JBOD across 8-10 M.2 interfaces!
MadMatt
November 30, 2022, 6:16am
2
X12SPO-NTF
Key Features
3rd Gen Intel® Xeon® Scalable processors, Single Socket LGA-4189 (Socket P+) supported, CPU TDP supports Up to 270W TDP
Intel® C621A
Up to 2TB 3DS ECC RDIMM, DDR4-3200MHz; Up to 2TB 3DS ECC LRDIMM, DDR4-3200MHz
Up to 2TB Intel® Optane™ Persistent Memory, in 8 DIMM slots
1 PCI-E 4.0 x16,
5 PCI-E 4.0 NVMe x8 Internal uhh Port(s)
M.2 Interface: 2 SATA/PCI-E 3.0 x4
M.2 Form Factor: 2280/22110
M.2 Key: M-Key
Dual LAN with Intel® X550 10GBase-T Ethernet Controller
Intel® C621A controller for 10 SATA3 (6 Gbps) ports; RAID 0,1,5,10
Supports 10x NVMe drives via SlimSAS connectors
Or
‘’‘X12SPM-TF
Key Features
Intel® C621A
Up to 2TB Intel® Optane™ Persistent Memory 200 Series, in 8 DIMM slots
4x NVMe port PCI-E 4.0 x4 via SlimSAS connector
1 PCI-E 4.0 x8,
2 PCI-E 4.0 x16,
4 PCI-E 4.0 NVMe x4 Internal Port(s)
M.2 Interface: 1 SATA/PCI-E 3.0 x4
M.2 Form Factor: 2280, 22110
M.2 Key: M-Key
Dual LAN with 10GBase-T with Intel® X550
Supports 12V DC power input
5 USB 3.2 Gen1 (2 rear, 1 Type-A, 2 via header), 6 USB 2.0 (2 rear, 4 via headers)
Should get you started…budget is going to be ‘interesting’ for 3tb worth of nvme…
I would resell them and look into getting two kioxia 4tb u.2s …
Unless you need it to specifically test some aspect of the nvme protocol/platform…
You can donate for Christmas to a few randomly selected people from the L1 community.
You can send it to @wendell and he will use it as rewards for people.
Create NAS storage for the L1 community.
system
Closed
August 31, 2023, 2:55pm
4
