So I'm building my first gaming pc and I already know how to hook up everything and choose my parts (Already done the latter, gonna buy everything on Friday). My question is fairly simple and I'm just checking if I'm correct, what do I need to do right after building the pc? Here's what I think I should do: 1.setup bios (did that before on my old laptop)
I personally install windows without the ethernet cable plugged in, install the motherboard drivers starting with the chipset driver, then install my gpu driver.
After that, I plug in my ethernet cable and install all windows updates until there are none left. Once that's all done, I like to take a system image so I can avoid all that work in the future if I ever need to format for some reason.
The build isn't final as it depends on what parts I'm gonna find/be able to pay for but here's a basic outline: CPU: AMD 6300 Motherboard: Some AM3+ motherboard, but idk yet HDD: 1tb caviar blue + some old hdds gpu: as expensive as i can pay but idk yet case: Thermaltake A12 chaser
