What should I upgrade?
So, I was thinking about this:
http://de.pcpartpicker.com/p/2uY1q
What do you guys think? I was also thinking about an SSD, just because I want to play to heavily modded The Sims 3 and Skyrim, and I could use the extra speed when loading. The main issues with modded Skyrim is that the game stutters heavily, and I can hear the hard drive working continuously. Don't know if it's the RAM, also, but I don't think it matters anymore.
I DON'T WANT to overclock, and shipping from Germany (I live in Italy) is actually cheaper than buying from here or UK. Anything I should correct?
EDIT: 450 euros is probably the best I could go with.
Also, here's the back of my power supply unit. Think it'll be enough?
4 +12V rails.  eh.  Just make sure you balance the items you put on each rail so you don't blow your weak +12V rails.
I think your GPU may actually be causing skyrim stutters.
Are you sure? It's the most powerful piece in my PC, and as I said, I can hear at least one of the HDDs working and stressing heavily when the stutters happen (when I mean stutters, I mean that sometimes they're quick, sometimes they can last even 5 seconds, and I recently defragged).
That happens on desktop too.
In general, the build you have now is outdated.  My C2D e8600 @3.33ghz was being maxed out on simple source engine games like TF2, and my 4GB of DDR2 1066mhz RAM was also being maxed out.
It'd help to know which specific GPU you have, though.
Also, what RPMs are your hard drives?
Sapphire HD6950HD 2GB, which I think is pretty good still.
My hard drives are 7200rpm, if I remember correctly. I have my games installed on the bigger hard disk, and the OS on the smaller, which is also older.
Well your whole pc is not very expandable, you may wanna look into some of the 400-500 dollar builds they post on their channel. They do allow for a few upgrades later on, and will get you going in no time!
If you can, play your games with Task Manager, and a program called GPU-Z open.  See what's getting high on the % usage, and then check again when you have your stutters.  If nothing occurs in the memory usage, CPU usage, or GPU usage graph, you may want to look into a Solid State Drive, if your hard drive is indeed the problem(highly unlikely though.  7200rpm drives should work just fine).
The builds posted on their channel include hard drives and GPUs, and I have those already, so I thought I could concentrate on MOBO, RAM, CPU and maybe an SSD.
The problem is that the pc completely freezes during those heavy stutters, and I can't do anything else. It happens in Red Orchestra 2 too, but only at the beginning of a match, when some textures are still loading.
Thats a really nice old 775 board you have there, you can easily push the 8400 to 4ghz +. Id do that first and see if it helps. A 6950 is still a decent performer. Just grab a new hdd (wd black or blue and or ssd).
If you are are noticing that the hdd is stuttering - run some diagnostic tests on it - HDTune etc. If speeds and seek times are shit, ditch em or use em for archiving. They are really slow hdd's to begin with... so dont expect much over 60mb's for an average transfer rate.
Running a heavily modded skyrim isnt the best of things to do - unless you like slideshows. Scale back the mods. Even on new systems a large mod list will make things chug.
Here is a build list - keep the 6950 & upgrade once you save up some more cash
http://de.pcpartpicker.com/user/deejeta/saved/3kBr
Thank you for the build list, but I already have these 2 HDDs for archiving, and a PSU, other than the GPU. I don't want a new rig, because with that budget I don't think things could last very long. What's wrong with this?
Nothing wrong with that parts list - I just wouldnt use that psu with a high end FX chip. Under full load the mb & cpu will draw close to half of what your psu can output (given that it wont be outputting anything like what is printed on the side due to age degradation and that its not the best of units to begin with. Keep it as a spare mate)
Your old hdds are half the speed of modern hdds (my wd blue is twice the speed of an EARS - trust me I have an old one myself. Unless you like long load times and slow boot times....
The PSU is 2, maybe 3 years old at max, I had to buy a new one because the old one died. It's not that old, anyway, but I get your point. Anyway, can you please explain better what do you mean with "Under full load the mb & cpu will draw close to half of what your psu can output (given that it wont be outputting anything like what is printed on the side due to age degradation"
So, if my new CPU and MOBO are under stress, my PSU will be over half of its capacity? How is that bad? I only have a GPU, I don't think my situation is that worrying.
Please excuse me for all these questions, but I prefer to understand things rather than being spoon-fed and stay ignorant.
Most power supplies do not output what they're rated, due to being made of cheap quality and "tested" at temperatures far below room temperature.  Also, if you're running your power supply at or around the max power output, it'll run both warm and less efficiently(especially if it's not 80+ cert.).
Also, I performed a couple of tests with that tool you suggested me (nice advice, by the way!) and I came to the conclusion that the HDD that is giving me trouble is the smaller one, the one where there OS is installed.
Do you think it's possible that, even if no game is installed on the OS HDD, it might still cause issues in games?
GODDAMMIT, this means that I will also have to change PSU?
This is getting expensive. Well, then, if I have to build an entire PC from the start, shouldn't I wait for Broadwell to come out? Or it's not necessary?
I think it would help us to give us your PSU make and model.
This is the one
http://www.game-debate.com/psu/index.php?ps_id=561&psu=Apex%20600W
Well, looks like that model has a 1 year warranty, which generally suggest a cheaply made PSU.  No 80+ cert of any type, and no efficiency rating on newegg :/.
Technically it should still work, as people don't immediately say it's terrible.
