What should i spend my income tax on when it comes in next year?
I am really bored so i decided to plan ahead on the upgrades i plan to do with my income tax.
Ok my current rig is this:
CPU:AMD [email protected]
CPU Cooler:COOLER MASTER Hyper 212 Plus
RAM:Crucial Ballistix sport 8GB (2 x 4GB)DDR3 1600mhz
GPU:SAPPHIRE Radeon HD 7970 3GB(reference card)
PSU:COUGAR CMX 1000w
MOBO:ASUS Sabertooth 990FX
CASE:COOLER MASTER HAF 932 Advanced
ODD:cheap Samsung DVD-RW
SDD:OCZ Agility 3 60GB(3gb space left)
Sound Card:onboard sound
HDD:1x 1.5TB Seagate SATA 2 drive(300gb of space left),1x 250GB Seagate(0gb of space,full of fraps recordings lol)
Keyboard:Razer Arctosa
Mouse:Logitech G9x
Headset:Logitech G35.and Turtle Beach X12
Speakers:Logitech X-530 5.1
Monitors:1x Samsung 23" 1080p monitor with tv tuner,1x 22" hannspree 1680x1050 monitor,1x 17" HP 1440x900 monitor
Ok last year i got around $850,but i got a $.40 raise since then and i could end up getting up to $1000 if i am lucky.
I am unhappy with my keyboard and my headsets,i also would not mind a new monitor,and use the 17" for something else,i am also worried about running out of storage space soon lol,i was also wanting to upgrade my cooling cause under a heavy load my cpu it got up to 59c which is only 3 c from what i read was AMD's suggested max safe temp of the 8150 which is 61c,but i was also considering gettinga second 7970.
There is so many things i could get, i have no clue what i should spend it on.
I know i should not really plan this far ahead,but i am bored out of my mind, and can't be on my rig right now,so i wanted to do this.
Just suggest as if i was going to do it now,and i will change the list later down the road as new stuff come out or prices drop.
Thank you guys so much for the help.
1.75TB and you're running out of space?
for a heatsink I would get a TPC 812
for heatsink fans I would get the Cosair SP120 performance
Well not only do i do fraps recordings which get big quick,but also my steam folder is almost 500gb just by itself(i have almost 120 games in total) plus i also have a lot of CD's and DVD's backed up onto my rig,and a 60GB ssd fills up fast.
Also i plan to do more than just gaming on my rig,i plan on trying to teach myself as much as i can about making video games until i can afford to go to college for it.
How much better would my temps be with that heatsink with those fans?
for storage issue i would get a 2 tb drive for fraps recording and buy another hdd dedicated to steam probly 1tb
Ok so far i am thinking of getting the heatsink and fans giga suggested,plus i am thinking of getting a 1TB and a 2TB WD black(let me know if you think i should pick some other drives) for a total of $366.76 shipped.
What should i spend the rest of the money on?
maybe a new headset: http://www.astrogaming.com/a40-audio-system-astro-edition
and sound card if possible
You could also go for 2 WD red drives for a raid zero for fraps storage and convert another drive for steam
I just got some Corsair SP120's to replace my Cooler Master Sickleflows on my H100. The Sickleflows weren't giving me the performance I wanted out of my H100. Once I installed the SP120's my temps dropped by at least 5 degrees.
Also, the TPC 812 is one of the best coolers on the market right now, and it will be a beast performer with those fans. If you want even better cooling then you could always go with the Phanteks cooler or the Noctua NH-D14. The Phanteks is right up there with the H100, and the Noctua is only a couple degrees warmer.
If you need more storage space, I would suggest either WD Caviar Blacks or WD RE4's. You could always put them in RAID 0 if you need more speed out of them too.
Before you get another graphics card, I would suggest upgrading to a higher resolution monitor or getting several 1080P monitors for eyefinity. You probably won't be able to notice any difference between one card and two cards until you upgrade to a higher resolution. That's why I'm going to be upgrading to a 2560x1440 monitor (I have two 3GB GTX 580s in SLI).
I think i have decided on what to get,but whould love any any input you guys have,you 2 giga you master of budget buying lol.
Here is the list:
Western Digital WD Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive     (for steam)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Seagate Barracuda ST2000DM001 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive   (for fraps)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148834
ASUS VS229H-P Black 21.5" 5ms (GTG) HDMI IPS-Panel LED-Backlit Widescreen LCD Monitor 250 cd/m2 ASCR 50000000:1     (i will make this my main screen,and my mom has a cheap LG 1080p screen that i gave to her,i will talk her into trading for the 1680x1050 screen,then use the LG and my current samsung as my side screens)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236205
XFX Double D FX-797A-TDFC Radeon HD 7970 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150596
ASUS Xonar D1 7.1 Channels 24-bit 192KHz PCI Interface Sound Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132007
Corsair Vengeance K90  Black/Metal USB Wired Gaming Performance, MMO Mechanical Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823816002
Audio-Technica Audiophile ATH-AD700 3.5mm/ 6.3mm Connector Circumaural Open-Air Dynamic Headphone
http://www.newegg.com/Product/Product.aspx?Item=N82E16826402014
Crucial Ballistix sport 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model BLS2KIT4G3D1609DS1S00
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148544
Corsair Air Series SP120 High Performance Edition CO-9050008-WW 120mm Twin Pack High Static Pressure Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181027
COOLER MASTER RR-T812-24PK-R1 120mm Sleeve TPC 812 CPU Cooler Compatible with Intel 2011/1366/1155/1156/775 and AMD FM1/FM2/AM3
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176
Grand Total w/Shipping:$1,181.23
But i am thinking prices might go down on some of the stuff within the next 5-6 months which is how long it will be before i get my income tax,plus i can try and save up some extra money just in case,plus i think the extra is worth it.
What do you guys think?
