What should I look for in a 30 foot HDMI Cable?
I need a 30 foot Hdmi Cable to connect my tv to my computer, The cable will be going in the wall if that has anything significance. But I dont know very much about HDMI technology and I would just like to know what features/specs I should be looking for in a HDMI cable of this length. I will be running 1920X1080 over it.
I found these cables but I have no idea if they will perform well, What do you guys think?
http://www.ebay.com/itm/30FT-PREMIUM-HDMI-1-4-FULL-HD-3D-HighSpeed-Shielded-2160P-CL2-Cable-IN-WALL-RATE-/251383100720
http://www.ebay.com/itm/30Ft-HDMI-Cable-1-4-High-Speed-With-Ethernet-30-Feet-1080p-M-M-For-HDTV-/300808927385
A $1 HDMI is the same as a $300 HDMI ether will work
All newer HDMI cords are "highspeed" I think when HDMI first came around there was a difference but not anymore. Just go with what's cheaper. Also, the quality of the insulation on the cable (braided or rubberized etc.) is something to look at, if anything.
Well yes thats true, But I have heard that there is sometimes trouble with longer distances in hdmi cables. Especially when using 1080P at 30 ft.
The reason I ask this question is because I have seen people recommend 50 dollar hdmi cables from monoprice because people complain that the cheap alternatives do not support 1080P when the cable is longer. So what I want to know is if 30 feet is considered long enough that I would have to worry about this? I read this and they use 50 foot cables and there is a substantial difference in the cables, (cheap vs expensive). Will I get the same results with a 30 footer cheapo? http://hdguru.com/all-hdmi-cables-are-the-same-or-are-they-full-test/4373/
Also in the reviews section of this product on newegg there are a lot of people saying the cable dosnt work and on most of them the manufacturer will respond saying that "It is the length that caused the poor quality display. Not all computer graphic cards can handle 30ft. HDMI cable. The recommended HDMI cable length is 15ft. or less." Even though the grammar isnt the best I think what they are saying is only a 15 footer will work on a pc. Is this true?
http://www.newegg.com/Product/Product.aspx?Item=N82E16812186030
There should not be difference i have a £3 15ft one to plug the tv in when i get bored works fine...why do you need 30ft? thats rather long.
Cheap, that's it.
I have a 25 foot cheapey DVI->HDMI cable that I grabbed on Amazon and it has worked fine through two PC builds. So no, PC's have no problem running over 15ft. Probably just the manufacturer trying to worm out of doing a crappy job with the connectors.
Which would bring me to my only point I look at for cables like HDMI. I look at the connector, make sure it looks sturdy.
On amazon I even look to see if there are any customer images with it taken apart to see build quality. Also search the reviews with the keyword "connector" to see what people say about that. On cheap cables I find more often than not that will be the failure point if there is one.
That said my 25ft cable was on sale for about $7 when I got it, it's $12.95 now but that still isn't too bad considering the length. Company that makes it is BlueRigger but there are many good cheapo cables on amazon.
Same company that made my DVI->HDMI makes a 25ft HDMI->HDMI for $13.99 if you don't need the full 30feet:
http://www.amazon.com/BlueRigger-High-Speed-Cable-Ethernet/dp/B005LQ83EI/ref=sr_1_13?s=electronics&ie=UTF8&qid=1386809550&sr=1-13&keywords=30+ft+hdmi
my tv is 27 ft from my computer..... Thats why I need a 30 foot cable haha
This was very helpful, Thanks :)
Quality of the cable doesn't matter for digital video and audio, unlike analog. Like others have said, whatever is cheapest.
