I got $$200-250s to spend. Looking for suggestions was thinking about a Radeon HD 7870 (Tahiti LE). Whatch think?
Thanks
MM
P.s. my budget is a little loose
Thanks
MM
I say the 7870 "XT" is a very good choice for that price point. But keep your eyes pealed. if you see a 660ti or 7950 dip into that range BUY IT.
Just be checking newegg or is there somewhere else?
Meh, everywhere.
But you probably won't find one. in that case get the 7870XT
like this http://goo.gl/h2TlO
Both those are just out of the price range. But like i said if he can find an epic deal GET THEM!
they are on sale for less. so thats why i was looking at them. Which is better of the three? (for gaming) really I can take other suggestions.
Bump
