Hello I was just wondering what average FPS I Should get in a benchmark like heaven Ungine. My computer has the following specs:
motherboard: maximus v formula .
CPU: intel i5 3570k @ stock speed.
Graphics Card: Asus Geforce GTX 670 4gb Direct CU II.
RAM: Corsair Dominator 8gb 1333Mhz .
PSU: Corsair gold AX 850w modular.
SSD: kingston hyperx 120gb
HDD: 1terrabyte, 5400rpm.
case: cm storm trooper black edition
Is this a good computer? Im just wondering if i have done some horrible choices!?
This would be a great computer.
But if you are not running multiple monitors or you are not playing in resolutions over 1080p you dont need the 4gb 670 the 2gb would be a better option also 1333mhz ram would hold back the system maybe take the money from the video card and put it into some BEAST memory from kingston aswell as a hyper 212 evo for a cpu cooler
Hope it helped!
Do you own this computer? Because I don't believe the Maximus V Formula fits in the CM Storm Trooper. I know this because thats almost exactly the setup I wanted, and when I contacted Coolermaster, they said it wont.
Though the Formula isn't that size, it still blocks the wiring holes.
I think hes asking for reccomendations on the build TO PURCHASE not like he owns it... but I dont know
Hi there, I have this build, the maximus v formula fits perfect!
If you have the build then why are you asking about a free benchmarking program instead of just downloading it and running it yourself?
I smell tom foolery
im asking what I should get, maybe I've done something wrong? I get something about 42 fps average in full settings of heaven benchmark. Is that bad or good? Thaugh i would get like 60 and up, maybe im wrong.
I don't know, but 42 fps sounds about right, these benchmarks are often very harsh, so it woundn't surprise me.
thanks for answers, s o my card is doing well ?
