Here are my specs for what I plan to build. (http://pcpartpicker.com/p/3KIXV)
If there are any changes i should make please respond. I want a gaming pc that can play 1440p perfectly, max games out and still get a constant 60+fps. Also its a budget of $1990 canadian. Thanks :D
This is what I put together. i5 and the R9 290 will go a really great job of powering a 1440p panel. I included a panel in the build.
Alternately:
http://ca.pcpartpicker.com/p/3N7qq
You might stretch to this. For just over your budget, you could get a 780ti with an 8320.
I had to reduce the storage, but you can add more HDDs later.
The i5 is equal to the i7 in gaming, and a perfectly capable productivity CPU. The 8320 is a very capable CPU, too. No need to get an i7 if you're only gaming.
Meh should just get this instead. You can at least use it to upgrade to broadwell at some point in the future without having to fork out this amount of cash again. Did I mention it is platinum certified? http://www.amazon.com/Rosewill-Platinum-Certified-Supply-FORTRESS-750/dp/B008G9MX48/ref=sr_1_1?s=electronics&ie=UTF8&qid=1400532933&sr=1-1&keywords=Rosewill+750W+80+PLUS+Platinum+Certified+Power+Supply+FORTRESS-750
You really need to bump up the GPU. The 770 is a good starting point, but it is no guarantee of 60 FPS. You have the option of an R9 290, and I was able to fit a 780ti in one configuration.
Editing suites are GPU accelerated. It will pay dividends to get a powerful GPU before you consider most processor or RAM upgrades.
