Here are my specs for what I plan to build. (http://pcpartpicker.com/p/3KIXV)
If there are any changes i should make please respond. I want a gaming pc that can play 1440p perfectly, max games out and still get a constant 60+fps. Also its a budget of $1990 canadian. Thanks :D
try amd fx 8350 and get a 780 for 1440p. the 770 will choke on high/ ultra
https://teksyndicate.com/forum/build-pc/what-should-i-build-beast-rig/178410
Double post. Just plugging the link so OP gets all the proposed configurations.
maybe something like this http://pcpartpicker.com/p/3N9LO is you are willing to add another $150-200 USD then get a 780ti instead of 780 getting a 4770k instead of a 3770k is worth the about $10 USD extra
