I am currently in the process of finalizing my PC build and now all I need is a PSU. This is my current build now:
http://pcpartpicker.com/p/uZa5
With that build what wattage PSU will I need? I was thinking around 600-700W but in the future I plan on getting a second GTX 670 and doing SLI and I plan on overclocking as well. And if anyone has any personal recommendations of a PSU they have or have had in the past that they really liked please leave a comment below. Thanks!
I'm always a bit skeptic with PSUs. I have a similar build to what ure buying and im using a Corasir TX750. Jerm1027 is right, 700W will do the trick. However i wouldn't be so sure to SLI the 670 and OC the rig with only 700W. For that kind of use i'd go at least 800W
If you want to spend the money, I personally would go with a Corsair AX760i, but that's just my opinion. Its plenty of power for what you intend on doing in your system.
Here is how much a GTX670 SLI system can pull: http://www.guru3d.com/articles_pages/geforce_gtx_670_2_and_3way_sli_review,4.html
That is 433w and that is with a OC i7-965 which is quite power hungry, a quality 550w will do the job if you want. Heck get a 650W just for good measure and there you go.
http://pcpartpicker.com/part/xfx-power-supply-p1650snlb9 This is a XFX 650, 53amp 12v rail a 5 year warranty and two 6pin and two 6+2 pin pci-e connectors all for $65, it is a heck of a deal.
