Hey everyone on TekSyndicate
I am wondering what PSU wattage I need to get. Many PSU calculators tell me 412W maximum but I am a bit skeptical about it. What would you guys say?
Specs:
1x 120MM LED FAN
FX 6100/6300 NON OVERCLOCKED STOCK HEATSINK
MSI HD 7850 OC 1GB
8GB DDR3 (2x4GB) LP Corsair
1x 500GB Barracuda, Seagate
(maybe an SSD depending on my money)
Mid end motherboard
3x USB Device
That's all I have connected. What PSU wattage would you recommend? 450W? 500W? 600W? If I plan to upgrade, I won't be going over the top. I will only get 95W CPU's with AM3+. I will also not get any other the top GPU's if I upgrade. So, what is a good PSU for the time being out of these?
http://www.scan.co.uk/products/450w-powercool-pcpc450auba-80-plus-sli-crossfire-quiet-fan-atx-v22-psu
http://www.scan.co.uk/products/450w-xfx-pro-core-edition-p1-450s-x2b9-85-eff-80-plus-bronze-sli-crossfire-eps-12v-fan-atx-v231-psu
http://www.scan.co.uk/products/500w-silverstone-sst-st50f-es-strider-psu-silent-80-plus-atx-12v-23-24x7-use-ready!
I would like to know what I need because I am on a semi tight budget (Need to afford a monitor, a mouse and a gaming PC under £560)
