What psu should I use?
What psu should i get? i need it to support the following system:
GIGABYTE GA-Z77X
Intel Core i7-3770K
MSI N660 Ti PE (sli 2)
COOLER MASTER Hyper 212 EVO
G.SKILL Ripjaws X Series 32GB 1600
Antec DF-85 Black steel/ plastic ATX full tower
WD 1t hard drive
750 watts for starters, go a bit higher if you can and try and buy good brands (seasonic,corsair,antec) ect.. you can go online and check some psu calculators for your setup and what you might possible add
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087
Well, I put your system together on PCPartPicker from the parts you listed.
http://pcpartpicker.com/p/oHVs
The Estimated Wattage is around 520W for the system. It's obviously going to be a bit' more than that. So I would recommend a power supply that's 80 Plus (Bronze or higher.) Also, make sure it has a single 12V rail, and be sure you purchase from a manufacturer that uses Japanese Capacitors. I would recommend a SeaSonic, NZXT, or a Corsair power supply. I personally would recommend a PSU that's modular, it makes it a lot easier to manage cables because you only use what you have to. Here are a couple that I recommend;
- Corsair Professional HX750 750W ATX12V v2.3/EPS12V
- SeaSonic X Series x750 Gold 750W ATX 12V V2.3/EPS12V
(Both are fully Modular)
Hope this helped,
              - jn
