So i currently use the HPC-620-A88S 620watt psu with a dual 80mm fan design. But yesterday i bought some pc stuff with a Inter-Tech CP 750w (non plus version)
now is it a good decesion to replace my HPC with the CP? the main reason to say yes is that the CP is much more silent. but they are both older? or just not so populair brands. so is it wise?
Well.. Their both generic, and their both multi-rail designs.. So, IMO, neither.
But IF you had to choose one, or the other -- for whatever odd reason..... -- I'd go with the 750 watt PSU. It's 2 rails, instead of 3. And it has 30 amps on each of those rails. And the efficiency is probably the same on those two PSUs.
Now, back to my opinion. Don't get either. And if you already have them, sell them to some unfortunate person, and buy a better one.
If you have to then go with the 750w but to be totally honest they are sketchy as balls and I wouldn't put either of them in a system. When/if you get a chance try to sell them like what @Jason_Thongphetmanic was saying.
