I am considering either a i5 3570k with a gtx 770 16gb build for £809 ($1285), or saving money by buying a gtx 760 with all other components as before for £676 ($1073). I will be using my pc for gaming eg bf4, film processing and autodest inventor. I would also appreciate any other pc recommendation for a similar price, baring in mind that pcs cost more in general in the UK.
theres not a lot of difference in performance in the 2 cards you mention. if you cant afford a 780- the the 760 is the better option as far as price to power goes. you would also get slightly better performance from autodesk with an amd 8 thread cpu like the 8350 as the 3570k is limited to 4 threads. so you would see a bit of a difference when the cpu is maxed out...
although autodesk can use cuda i would still choose a larger threading cpu to balance the overall system.
You really shouldn't consider the GTX 760 currently, the Radeon HD 7950 only cots ~$200 and offers equal if not more performance and it also get a higher performance increase from overclocking.
but its not very well supported by autodesk. nvidia iray is shipped with it as 1 of the default renderer's. where as vray (ati gpu renderer) you have to download as a plugin and it does have issues... i know this because i tried Vray myself...
iray is more stable, better supported out the box.
while above is rite in the 7950 is a better value and in some cases performance card. it does get trounced on autodesk as far as gpu based render goes.
at least in my experience.
Thanks for the reply, and I have to use inventor as it is what my school uses as well as all of the universities that I am applying for.
Also do you think it is worth waiting for the amd volcanic island series of gpus.
