I've got Thermaltake V3 Blacx Edition. It's cheap, but damn good for the price. Can fit long heatsinks, a little though not a lot room for cable managment. I also put some stickers on it. http://www.newegg.com/Product/Product.aspx?Item=N82E16811133094 http://postimg.org/image/9bn7fod7h/
Yeah! I'm the only fractal define mini! lol. I'm not showing her off, she's a budget build
Cooler Master elite 431 plus
My current case is a BitFenix Colossus:
full ATX tower, this thing is a beast!
Shortly will be replacing the side panel for the Colossus Window Panel, so I can show off my build once I upgrade the internals and has 2 120mm fan mounts on the window, might also replace the front 230mm with a BitFenix Spectre Pro LED (Red) 230mm to match the internal colour scheme. Will also be removing the top 230mm with the Corsair H100i rad for push config.
I use a clear acrylic open air atx bench case from MYOPENPC. works great, keeps everything cool. Dust might seem like a problem, but since its all open it takes all of 30s and a can of air to clean it out.
http://www.amazon.com/MYOPENPC-Transparent-Acrylic-Stackable-Capability/dp/B004TZAU1Q/ref=pd_cp_pc_0
http://www.tomshardware.com/reviews/midi-towers,1011-29.html
Cooler Master Elite 370
It's good for the price. Aside from not having cable management, I only don't like that PCI-e slot covers are not reusable. The case fits long GPUs and high coolers and has many fan mounts.
I use a Zalman Z11+, InWin Malestrom and InWin H-Frame
1 http://www.newegg.com/Product/Product.aspx?Item=N82E16811235034
2 http://www.newegg.com/Product/Product.aspx?Item=N82E16811108190
3 http://www.newegg.com/Product/Product.aspx?Item=N82E16811108431
I own a 650D. It's pretty awesome. But I feel Corsairs nameing pattern makes me feel like I don't own a high end case any more... 900D, really?
Z9 plus represent! I have one too and I love it. Such a great value for the price. I'm with you on the LEDs, though; I just ordered LED-less replacement fans.
