I need a cpu, motherboard, gpu, and psu for a gaming pc. My budget is $300.
I want to be able to play bf4 on meduim-high settings
I live in the USA
Any help would be appreciated
I live in the USA
With that budget, the best you can do is an APU set up. I am assuming *(and hoping) that you already have a case and a cd drive. With that in mind, this is the best I could do. You can cut back on the cpu if you want to get it under $300. I would say to go with the A10-5800K if you do plan to do that.
http://pcpartpicker.com/p/19TNu
Yeah, that's pretty much the best you're going to get for $300^
You're not going to be playing BF4 on Medium to High settings though. You might be able to if you throw in a Radeon HD 6670 and run it in dual graphics with the APU though. A better option would be to save up and throw in a more powerful dedicated graphics card and run it on its own.
i suppose he gonne need a dedicated gpu to play BF4 on high..
I already have 8gbs of ram, a case, cd drive and hard drive
If he wants toplay BF3 on high or ultra, he will need something along the lines of a 7850 or a 650ti boost. You are going to need to increase your budget for the performance you are looking for, man.
http://www.techspot.com/review/661-nvidia-geforce-gtx-650-ti-boost-sli/page2.html
Here is a better option for you, seeing as how you already have ram. It should work for 720p and will leave much more headroom for upgrades than an APU build.
http://pcpartpicker.com/p/19Uok
what if i repaced the cpu with the AMD Phenom II X4
That should work great.
alright thanks for the help man really apreciate it :D
