What motherboard Should i get?
I am wondering what fits best in a NZXT Guardian 921 RB Crafted Series Gaming Case with an AMD X8 Fx-8350 processor, basically what im trying to get is the best fit for the case itself and the motherboard along with the processor. Although i do want to have a motherboard that is suitable and isn't pricey, because i am on a  budget i am probably going to go for maybe $100-$130 on the motherboard because my budget total will work out to about $600-$800 in total depending how my budget changes over time. But the only thing is, i am probably not going to be overclocking, but just in case i do i wont narrow it down to anything just yet.
990fx board. just stay away from the gigabyte boards.
  1. Aus crosshair V Formula Z.
  2. Asus Sabertooth 990FX R2.0
  3. Asrock 990FX Extreme 9
  4. Asus M5A99FX pro R2.0
List of decent and great overclocking boards for the FX8350.
You are a Good man.
( +1 )
lolz thank you?
