What monitor
I am looking for a 1080p x 1920p ips monitor between 23 and 27 inches, at the moment I have either the asus PB238Q or the asus PA238Q but the problem with those is that their quite old and they also have a few problems. this is my first build btw. so if you have any other suggestions that would be great, and if you think these two monitors are ok could you please tell me what you think of them.
Thank you!
https://forum.teksyndicate.com/t/best-1080p-ips-gaming-monitors/79278
Literally under a day ago.
I like the LG IPS ones.
Check them out probably; http://www.lg.com/us/ips-monitors
Best wishes! :)
