What laptop spec i should go for
im going to college and i need a laptop i want it to be able to run league of leagends and starcraft 2 all the other games that are hardware intensive will go to my gaming desktop
for starcraft 2 im hoping for medium setting at 30+fps
so my question is what hardware should i be looking for?
my budget is 600$ max the cheaper the better i cant spend too much on a laptop
im thinking that a amd a8 or a10 whit their integrated graphic would it be able to do the job?and any suggestion of hardware that could do the job better at similar price?
also the reason i need it for college is for programming and more
so any help/subjection  would be appreciated and thank you for your time on helping me
What screen size are you looking for?
doesn't matter
I have been very happy with my a10 laptop. I does get hot quickly when gaming though
Here are some options to consider. The Intel HD 4000 iGPU should be enough to run Starcraft 2 on medium settings. I Would advise you to throw a Linux distro on your laptop when you get it, lol and SC2 run pretty well in wine.
http://www.amazon.com/ASUS-Ultrabook-S500CA-DS51T-15-6-Inch-Touchscreen/dp/B00BC4QMVE/ref=sr_1_3?s=pc&ie=UTF8&qid=1378425936&sr=1-3
http://www.amazon.com/Toshiba-Satellite-U945-S4130-14-Inch-Ultrabook/dp/B00AY1FHZS/ref=sr_1_1?ie=UTF8&qid=1378426351&sr=8-1&keywords=Toshiba+Satellite+U945-S4130
