What KVM maybe?
Hello,
I’m looking for a solution which can support my use case. I got a desktop & a work laptop and requirements are as follows:
Inputs to KVM
  • usb keyboard
  • usb mouse
  • usb headset (optional)
  • desktop output AMD 7800xt (has multiple outputs)
  • MacBook pro M3 (usb-c)
The desktop is Linux only and currently runs i3wm with 2x display ports @144hz
Ideally I’d like to be able to use at least 1 big screen preferably 2 and mouse & keyboard when I sit down to work on MacBook for work.
Any suggestions? Doesn’t have to be KVM just don’t know a different way :confused:
Thanks
