Okay so I have used a Ducky Shine 3 with Cherry MX blues and so far i seem to like it i'm just wandering if there is a better key switch that has the same actuation points and the bump but doesn't bottom out as quickly.
Well there's Cherry MX Green which is like blue but with about 30 grams more actuation force if that's what you're looking for.
All Cherry MX switches bottom out at 4mm. You can reduce bottoming out depth using o-rings but there's no way to increase it.
