Hi,
I'm looking to build my first pc using an ASUS H81M-E, an intel core i3 4160, and a r9 280x. I've been reading poor reviews saying that this board while claiming to support 4th generation Intel core cpu's it requires a bios update which is difficult to go about. Is this true? Also, could I upgrade the i3 to an i5 4690 later on with this board for more performance?
Thanks so much
I think you might have a problem using that motherboard and CPU.
The 4160 was released on the 20th July last year, so it's probably a Devil's Canyon part. This will mean that, unless the motherboard has the latest UEFI when you get it, they won't work together. Look at getting a 9-series chipset board (e.g. H97) to be 100% sure it'll work with your CPU.
It would normally be okay to buy combinations like this with ASUS boards because they usually have a feature called USB BIOS Flashback, which means you can flash a new bios via USB without a CPU installed. Unfortunately, this board doesn't have the feature.
You're the best thank you
No problem.
