Its time I got a new PC for gaming. I need to know what Combonation of CPU, GPU & PSU I should get that won't be massive overkill for what I will be using them for.
I plan on overclocking the CPU at some point so lkeep that in mind,
Here is what I need the PC to run at the highest settings possible:
- World of warcraft.
- EVEonline.
- Minecraft played like this
- Just Cause 2 (can be on lower settings)
http://pcpartpicker.com/p/GgkP
I just picked a random case anything that fits atx would fine
you could also get a 650ti if you need cuda
If you were to rate the FX-6300 to a FX-8350, where would you put the FX-6300 on a scale from 0 to 1000, where 1000 is the FX-8350 & 0 being an apple?
All things considdored..
Well if you're playing WoW you definitely want Intel and Nvidia. So basically i5 3570k, a gtx 660, and a good 550w PSU from corsair or seasonic (or other reliable companies)
