What is the point of having two GPUs?
First off, sorry for being such a noob haha. In my rig that I am going to have for Christmas, I have a GTX 760 in it. I was wondering what is the point of two GPUs? If I put in a second 760, what more can I do with it? Thanks.
My upcoming rig:
AMD FX-8350
GTX 760
16 GB of RAM
2TB HD
Windows 8.1
a theoretical doubling of computing performance
you get to use more electricity muwhahaha
In real world terms; you can play games on the highest settings with less of a performance trade-off (a drop in framerate). However, not all games will work well with a dual GPU configuration.
The GPUs help each other out.
You actually only use 1 of the GPUs in the computer and the other as a cup holder on your desk to protect it from water marks. That's what the Pros do. I have no idea where they get the names "Crossfire" or "SLI" from that though.
Dual GPU's really benefit during workstation related tasks.  I develop games so i use tons of programs that actually utilize more than 1 graphics card at 100% utilization. So rendering is the big one, like doing a Maya/Max render that would take maybe 1 hour can be cut down to 30 min(literally).  I did that before with dual 6970's overclocked 30% on both memory and core.
If you're doing dual GPU for gaming, i would recommend upgrading before you do dual graphics.  Main reason is because MANY games don't scale well in performance.  Some games you may get 90% utilization(max a second card can give).  Some games will give you 40% and even some with no benefits what so ever. It's more guaranteed and better for your power bill if you run a stronger single card.  Like a 780 or a 290.  Then dual cards would be fine, but dual gfx on inferior cards generally lowers the value to performance.  It's kind of a double edged sword, i know many people dual carded their 660's and then were kind of bitter because they didn't get the performance improvement they wanted.  Majority of the time, if you're going to play a AAA title like Crysis 3 or BF4, you'll get good performance. Doing so with indie titles like Path of Exile will give you like 20% improvement and higher power consumption for nothing, just to split the load.
Depends if your mobo is even capable of SLI a lot of AMD mobos dont support it (SLI needs a minimum of x2 pcie x16 slots @ x8 x8)
+1 anything below that isn't worth it and you would lose a lot of performance from the cards.
You can virtualize windows and do a PCI passthrough.
Thats pretty good!
Do you have a 990FX chipset board in the first place? to even be able to run a sli setup..
Anyway im personaly not a big fan of dual gpu setups. reason why, is because you need a more powerfull psu, if you dont have one that is powerfull enough you have to spend extra money. Second if you play games that are good optimized for sli setups then its great, but there are also games that have not good optimized for it, and those games gonne be a pain in the butt.
Im personaly more a single gpu fan. i would say if you dont have any parts yet, save the money on the psu, and trow in a GTX780 or R9-290 if you can afford
Just post a video tutorial of installing a linux distro and virtualizing windows and gaming on it with custom allocated system resources. It would be much appreciated, be sure of that.
Maybe more people will be interested and I might try to successfully install linux one day (it still dissapoints in program and driver setup, it's a pain in the ass, no wonder it never had a significant market share).
