What is the difference?
I want to know the difference between AMD and Intel processors. Price, performance, endurance and compatibility. What is the difference ? Thank you.
Slightly loaded question :P
Intel - Expensive, Best Single Core Performance, Overclock Well, Low Power Usage
AMD - Best cost performance ratio, More cores (on the top end) , Overclocks well , changes socket less.
Each has it's pros and cons but the "difference" between them doesn't really matter, it's what you use them for thats the real factor when comparing the two.
Thats a fucking huge question that no one will even take the time to comprehensively answer on here, considering the broad range of products in both camps.
What not narrow it down a little by saying what application you're looking for, Gaming, home theater, workstation, server, Along with a price range.
Price, performance
AMD CPUs have better price/performance ratio from low to mid-end. Intel provides the best performance for high-end. If you are around $200, things get debatable, because there are close options like FX-8320, FX-8350, i5-4440, i5-4670k and it's hard to decide whether you need single-threaded or multi-threaded performance more and should you get one with overclocking potential or not.
compatibility
AMD generally keep things compatible for a long time, for example, if a manufacturer made a BIOS update and motherboard's specs are good enough, you can run FX-8350 on an AM3 motherboard that was made for phenoms. Intel change their sockets more often.
endurance
What does that even mean? Life expectancy? More than you need in any case.
You missed power consumption. It's generally higher on AMD CPU's. It's usually not important if you are running them in stock but heavily overclocked FX-83** can draw 300W. It also can be important for small form-factor low power systems.
