What is the difference between Antivirus and Internet security?
So i`v noticed that Antivirus is usually cheaper than Internet security and i was wondering what is the difference?
Internet security comes with more modules to scan and block internet and network traffic.
Usually is not necessary.
@Sorsdivjus ^^^^
@Sorsdivjus summarizes it well.
Getting a antivirus such as Avast, or if you're if wiilling to pay BitDefender. Then use MalwareBytes Anti-malware on the side. As for internet security uBlock Origin (an adblocking chrome and firefox extension) is generally all you'll need, most of what gives you malware on the internet comes from malacious ads (and infected programs, but your antivirus sorts that out)
