I recently decided that the left side of my car was looking to nice so this morning i figured i would lightly rearrange that side of the care using a guardrail. So i may not have as large a budget as i would like for an upcoming build. I'm just looking for ideas for low budget builds i cant quote a budget yet since we dont know how much the damage will cost im hoping it wont impact the budget that much but i would like to have options set up so that i can have something to fall back on.
Here's one that I had laying around on my HDD. Very Cheap andd extremely powerful for the price.
AMD A10-5800K 3.8GHz FM2 4MB 100W Black Edition £95.26
Gigabyte F2A75M-D3H AMD FM2 A75 DDR3 mATX £55.84
Seagate 1TB Barracuda SATA 6Gb/s 64MB 7200RPM Hard Drive £54.99
Patriot Memory 8GB (2 x 4GB) DDR3 1866MHz Viper 3 Black Mamba DIMM CL9 £36.72
Antec Earthwatts 380W ATX 12V 80Plus £36.49
Gigabyte IF233 Miditower USB 3.0 £30.99
Total: £300.19
Parts priced used Dabs.co.uk
Are the apu's really viable? What kind of performance do they have?
http://www.youtube.com/watch?v=z-caVy2WVUI
it does the job pretty good the apu has the graphics close to a 7750
http://www.anandtech.com/bench/Product/535
I believe even an A4 can deliver better graphics, let alone an A10. The 5800K is fairly powerful, with its CPU performance between a Phenom X4 965 and an FX-4100/4300. Then the GPU performance is like a discrete GPU. I can't really compare anything to it now, because I haven't researched in a while, but if I remember correctly, you can max out most games at 720p, some at 1080p.
http://pcpartpicker.com/p/zL4e
AMDs 'A' series APU's are the bees knees! At least get an A8!
You could probably grab a cheaper case or use one that is laying around, either way, I don't think spending almost $50 on a case for a low budget build is necissarry. Other than that, everything seems solid and I am amazed at how much lower of a price that build is compared to mine.
get the a8 5600k if you plan on getting another graphics card later. you'll save a few bucks and it has similar processing performance.
Get the AMD A8 5600K APU. I have it, running BF3 on Medium with 64 players on a large map with 20-25 fps.
A10 destroys the A8 in every way...
There's only one way to find out!
FII---IIGHT!
Please tell me someone gets the referance..
only the Brits amongst us will get the Saturday Night Blurb ref :)
Hey you can check my tread i have a build thats is a $400 or less. Its a intel processor and a r7 260x graphics card
