I’m trying setup a dual boot with windows and manjaro on separate disks with a raid array accessible from both os’s. I tried the raid on my b350 motherboard and learnt it doesn’t work on manjaro, is there a software raid solution.
Does Manjaro have drivers for your RAID controller?
AMD does seem to a linux drivers for raid but when ever I try boot into my linux drive with my sata controller in raid mode it just dumps me on the bios again. I will try switching to achi install the driver then switch back to raid hopefully that might work.
On Windows you need you need to plug a USB drive into the system and specify the drivers to load when you are installing Windows.
I don’t know if that also applies to linux, customise the installer image by adding the driver package?
