Okay, so I'm looking to upgrade my PC. I'm doing it incrementally, as I'm in high school and only have a part time minimum wage job. I'm trying to decide what order I should purchase the upgrades in. Here's the list of parts that I'm going to be getting, in no particular order: http://amzn.com/w/2DP6QPYQ98B30
My current specs are:
Motherboard: Intel DH67BL
CPU: Intel Core i5-2400 @ 3.1GHz
RAM: 8GB 1333MHz
GPU: EVGA GeForce GTX 550 Ti
Hard Drive: 1TB Seagate 7400RPM
Those are the parts I'm going to upgrade first, the rest come later. So what I'd like to know is what order I should do the upgrades to get the biggest boost as fast as possible. Of course, I need the new motherboard in order to use the new CPU.
The only thing you really need to upgrade is the GPU, which may require a PSU upgrade as well. The CPU and RAM are fine. An SSD will help with system response, and reduce loading times, but will have just about null impact on gaming performance.
One of the best bang for the buck GPU's is the 7870 XT (Tahiti LE).
For most people, no. The 7870 XT is about as fast as the 7950 in gaming, the the 7870 by itself is already capable of delivering playable frame rates on most, if not every game out, at maxed settings at 1080p. Plus, some of us like to save some money for games.
I agree with everyone about the 7870 XT, and if you can get over the fact that the blue PCB on the Sapphire one matches absolutely nothing, it has a really good cooling solution.
In regards to adding an SSD, make sure that you check and that your motherboard is compatible with SATA 3.0 6Gb/s, otherwise the controller in the SSD will cut your transfer rates in half, regardless of whether or not the connection could support the bandwidth. Also, if your motherboard supports it, I would later look into getting some faster RAM, at least 1600 MHz, if not faster. I like the look and price/performance of Patriot Viper 3 2133 MHz RAM
http://pcpartpicker.com/p/L9pG
The processor is only there to show what you already have
The thing is, you don't need to upgrade your CPU at all for the next 2 - 3 years minimum It's still an amazing CPU for being 2 years old...
Even if you do upgrade to an 8350 like you have listed in the wishlist your motherboard you listed is incompatible with it you chose an FM2 and it should be AM3+
