Lately I was using lots of PSU Calculators.
And as I went on the PSU Calculator of "eXtreme outer vision" I saw the CPU Vcore and the CPU Utilization bar, I did not understand any of it and now am curious what it is all about.
Since my knowledge about Hardware isn't huge I would love you to explain it to me in a simple way.
Simply put, the CPU Vcore - known as the CPU Core Voltage - is the amount of power (measured in volts) being delivered to the CPU.
This is very important to overclockers as raising the Vcore can cause stability and heat issues for the CPU - ergo greater amount of voltage increases heat output and total power draw.
There's also BCLK (Base Clock measured in Gigahertz or Megahertz) and multipliers to consider while overclocking as well. But that's getting a bit off topic. Hope this helps :)
Understood, and what about the CPU Utilization ?
I'm pretty sure that's even simpler haha
It's just the amount of resources being "utilised" by the cpu at any given time. Usually measured in a percentage with 100% being at maximum load.
For example:
The CPU, across the 4 cores of my particular CPU is using 8% of it's total load.
Ninjad while typing xd
Learning any type of programming language gives you the curse of 70WPM+ haha
Thanks a lot, simple and short.
I know java, c++ and python...
Im also on my phone xdd
No worries, glad I could help
oh god, I know Java, R, SAS and have to learn Python and Julia in the future
Ah yes, typing on a phone is also a curse haha
I have never heard of those languages... Hm...
TO THE GOOGLE!!!!!
