do i need a beefy computer to...i don't even know what a bit coin is, I've just heard of them
any replies are appreciated (anything to make me less n00b haha)
https://www.youtube.com/watch?v=Yg1JnbIS60g
Explains a lot & yes you will need good hardware or a lot of mid-range hardware to mine. Nothing to stop you from investing in it though.
If you get your electricity for free than mining can be worth your time and $$$ otherwise unless the $/kwhr is super cheap it'll take a long time even to break even.
There are PLENTY of threads asking the same question, please search google, or look through the forums before asking.
