What is an Encryption controller ( in an AMD CPU)?
Following is from lspci output on my debian 10 (proxmox kernel 5.4.78-2-pve, with an AMD Ryzen 5 PRO 4650G apu on an Asrock B450 Pro R2.0 motherboard:
0b:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at fc700000 (32-bit, non-prefetchable) [size=1M]
Memory at fc88c000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [48] Vendor Specific Information: Len=08 <?> Capabilities: [50] Power Management version 3 Capabilities: [64] Express Endpoint, MSI 00 Capabilities: [a0] MSI: Enable- Count=1/2 Maskable- 64bit+ Capabilities: [c0] MSI-X: Enable- Count=2 Masked- Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
My questions are:
1- what exactly is an “Encryption controller”? Do I have it because my CPU is ‘pro’? I am assuming some sort of hardware offloading, but more information would be good.
2- why doesn’t it have a kernel driver or a kernel module? do I need to install something?
Thanks,
It’s not because it’s a Pro CPU, I have it on a 2700X:
0c:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor
My guess is it either implements encryption functions in hardware, or it accelerates them in some way, would probably have to ask AMD for that :stuck_out_tongue:
As for your second point, it does (use lspci -k):
        Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor
        Kernel driver in use: ccp
        Kernel modules: ccp
Which is obviously the Chinese Communist Party living in your CPU :wink:
Hey, thanks for the reply.
You are right I have it in my other Ryzen CPUs as well. I also have the ccp kernel module in fedora (32 kernel 5.10.12) , but I didn’t have it in debian 10. It probably have something to do with the kernel version and not a missing package. debian 10 is on 4.9. Anyway, now that I know what I am looking for, I’ll find it :slight_smile:.
Thanks,
Given Ryzen and Epyc are the same die and Epyc supports encrypted memory (to shield VMs from each other etc.) it could be to do with that.
