What is a good RGB LED strip?
I plan to replace my case with the NZXT H440 and I want a RGB strip that make it so that the LED fades (transitions) through all the colors. Something like the NZXT Hue but that wont work for the H440 because there isn't an optical bay slot. So what is a good RGB LED strip? Thanks in advance :D
Icemodz make a great RGB remote control LED kit
The strips are all pretty much the same 5050 SMD RGB LEDs,
What you will need to do is look for one with a LED controller that has the transitional fade you want and can be powered easily from inside the case (there are some out there with Molex or SATA power connectors)
Or.... if your inclined to making things your self, this is a really good entry level project for micro controllers like the Arduino.
eBay. Use eBay. Ive getten several sets because they work perfectly.
http://www.ebay.com/itm/5M-Waterproof-RGB-5050-LED-Strip-24-IR-Remote-Power-/160519775068
You have to wire it yourself (just to the red/black cables from a molex) but the effects are amazing. And you have a remote!
