What headset do I choose?
Hi, I've recently been looking at another audio setup for my room. I'm rocking a Logitech G430 as of now, but I'm tired of having the microphone so close to me. Therefore I just ordered a Røde NT-USB. But I'm still missing a new pair of headphones. I'm currently looking at the Sennheiser HD 558/598, but I'm not sure that I'm going to like them.
I'm mainly going to use them for musik(Rock, metal etc.) and gaming.
Hope you guys can help me :)
Beyerdynamic, they are a bit spendy but you get what you pay for. Logan uses the Dt 880, the MMX 300 are the high end gaming headphones they produce.
As I mentioned in the main post: I am not looking for a gaming headset, I am looking for a headset for music and gaming without a microphone.I have been considering Beyerdynamic, and one of my friends got the DT 770. He reccommends it. But the two you mentioned are a bit pricy for what I am looking for.
Max budget is around 250$
The DT 770 you just mentioned would be a very good choice, but you'd need to make sure you get the 80ohm version otherwise you'll need an amplifier. Alternatively if isolation isn't important then the DT 990 would also be great, and it has a more "fun" sound signature and is open, so wouldn't get hot inside and would be ideal for gaming. (I think the 990 only comes in 250ohms though, so you will need either an amp or a very good sound card to get any proper sound/volume out of it)
