What happens when a power loss occurs on an open channel SSD?
Hello,
It’s all in the title :wink:
I would appreciate your help as I couldn’t find anything on the web yet !
… you get an unclean/partial write? Possibly causing a corrupt OS and an unrecoverable system?
Realistically, the write is junk, and the system just ignores it.
A bunch of power cuts strike all over the place, and systems almost always keep going.
Real problem is if you are contributing to a system that requires uptime like a company database
Hey thanks for the follow up.
What do you mean by :
Okay, was just spitballing, but I don’t think we as normal need to worry about sudden power loss.
Businesses have UPS systems to keep machines running for a short time.
You can get a UPS if you wish for peace of mind, and they are not too expensive.
I personally am not worried that much about the loss of data across my systems, and have not chosen to use a UPS.
