What happened to 20nm
What happened to 20nm on the new cards, 256 tmus, 4000 cores and what's with the new naming scheme,
Seems like a rebranding of cards and one new powerful card, like what nvidia did.
Hawaii is just reworked Tahiti chips. So yes, it's practically a rebranding. I think it was a well known fact (educated guess) that Hawaii wouldn't be 20nm, even months before it's announcement.
I don't see why, we already have 22nm Intel chips and they had a long time to develop the new cards.but why not use a larger die to fit more stuff then?
Yes, Intel has 22nm fabs. Intel also has many billions of dollars to throw around for research and development.
Global Foundries and TSMC, who make AMD and Nvidia products, don't have the budget that Intel has. That's probably the biggest reason.
They don't just make the die larger because that costs more, yields less, and has a higher failure rate per chip.
I'm sure they could have increased the die size by 30 percent,  I highly doubt that would be that expensive, the gtx titans die is around 550 mm^2 size the 290x is 424.
They did increase the die size over the 7970. And it was by almost exactly 30 percent.
352 mm^2 on Tahiti, ~450 on Hawaii.
I don't think amd has confirmed/denied any of the rumors beside transistor count, mem bandwidth, and Tflops
I'm gonna have to look into it further to find the exact source, but the ~450 die size came from an AMD employee of some description who said Hawaii is 30% smaller than a Titan. From that, people guess anywhere from 430 to 480.
Edit: Here it is.
"[Nvidia's Kepler] GK110 is nearly 30% bigger from a die size point of view." From Matt Skynner, "Corporate Vice President and General Manager of AMD’s Graphics Business Unit".
Maybe when Apple begins the shift to TSMC and/or GF for their processors those companies will have a bit more to spend on R&D
I believe you people have some things confused
Die size has little to do with manufacturing process size
a larger die means more stuff, a smaller manufacturing proccess (nm) means you can pack more stuff within a area, they probably have a lot more cores or did what intel and AMD have been doing by packing more and more things on the chip, like how they basically put the whole north bridge, USB 3, sata,  PCI-E controllers, memory controllers and some VRMs, those would increase the die size regardless or the nm decrease because there was so much stuff
i know what die size is, its how large the actual piece of silicon that we call a GPU is. I'm saying use more silicon, larger die, and you can get more cores tmus rops ect.
oh I wasn't referring to you, the other guys in the thread
I don't see who is confused. The topic title refers to manufacturing process but most of the conversation has been about die size, but nobody was confusing the two...
Wonder when they will get 20mm sorted at TSMC
